Well the best way to find it is to connect up a smoke machine and a Tech 2 scan tool and follow the test procedures for the EVAP system. If you don't have those tools handy then post the actual code you have.
There are about 4 parts that cause most of the leaks on these vehicles.
Having the code narrows it down.
The most common one I encounter is the vent solenoid located under the rear of the vehicle above the front of the spare tire. They get sticky and don't close.
The next is a bad fuel cap.
Next on the list is the actual sensor on the fuel pump module.
However without the code and some tests your shooting in the dark.
SPONSORED LINKS
Friday, December 4th, 2009 AT 9:58 PM
