1996 Chevy Blazer coolant leak
180,000 MILES • 6 CYL • 2WD • AUTOMATIC
LILENGLAND1Q
i was driving at night time and started smelling coolant which began to fog up my windows when i turned on the defrost, it got worse and some white fumes were coming in from the air ducts. the carpet on the passenger side was getting soaked with coolant and when i looked under the passenger side behind the front wheel, i noticed some leaking from the hose. Could this problem be fixed by simply replacing the hose or is it more major than that?
May 28, 2008 at 12:22 PM
MASTERTECHTIM
  • 4,750 POSTS
most likely your heater core has failed and needs replacement. this is inside the dash
May 28, 2008 at 12:23 PM
