1996 Chevy Blazer cold!!!!!!!!!!!!!!!!!!!!!
226,000 MILES • 6 CYL • 4WD • AUTOMATIC
LGKB
had low air pressure put air hose in vent on floor to clean out vents and has good air pressure but now it is blowing very ccoolldd air only
Jan 13, 2010 at 2:59 PM
BILLYMAC
  • 2,204 POSTS
you have a blend air door under the dash that is not closeing. open it manually. if good heat replace the controller for that door
Jan 14, 2010 at 12:35 PM
