This is what i have done so far, I tested the ignition system and all cylinders fire except # 1 and # 2. I inspected the Distritor cap and rotor and they seen to be ok. Also i could not locate the Fuse/Relay for the Fuel. So when i tested each cylinder the vehicle started. What do you suggest from here.
Mar 6, 2010 at 10:43 AM
