1996 Chevy Blazer check engine light flashing
PMR1ROSE
Computer problem
1996 Chevy Blazer 6 cyl Four Wheel Drive Automatic
what would cause my truck to misfire?
Mar 30, 2009 at 5:37 AM
EUGENE123
  • 273 POSTS
a misfire will happen for a few diffrent reasons one being that the truck is out of time, another would be no spark to the cylinder that is misfiring which would mean bad plugs or bad plug wires another would be the distributor cap being bad
Mar 30, 2009 at 6:33 AM
PMR1ROSE
thanks.. the engine light started flashing this morning when i started it and it ran really ruff. the engine has been rebulit and i just had the transmission rebulit.So your telling me that all of a sudden my plugs could go bad?Now the light just stays on.
Mar 30, 2009 at 7:02 AM
ZACKMAN
  • 4,202 POSTS
Flashing check engine light means that your vehicle is running out of its safety parameter that may cause severe damage to the catalytic converter. In other words. , if the vehicle is running severely rough, it may set the light to flash. Have the computer scanned for codes and post the code numbers here for proper diagnostic.
Mar 31, 2009 at 4:23 PM
PMR1ROSE
I took the truck back to transmission shop because they forgot to tighten the battery bracket and im thinking the cables also. They offered to check the computer code for me PU300 Eng. misfire detected.
The light is no longer on and the truck runs great again so whats up with that?
Mar 31, 2009 at 6:08 PM
ZACKMAN
  • 4,202 POSTS
I am not sure. They may have discovered an unplugged sensor, a ground or something. If the truck is running good now and no check engine [light on, I wouldn't worry about it. The next time it happens, though, get the code scanned again and let us know.
Apr 2, 2009 at 3:30 PM
