1996 Chevy Blazer buckled wheels
196,258 MILES • 6 CYL • 4WD • AUTOMATIC
MIKE559
i have a 96 chevy blazer 4wd truck and my two front wheels are buckled inward and not just a little
i mean they kinda look like a car with hydroulics that has its front wheels bent in . what is causing this a nd how can i fix this
Oct 8, 2010 at 10:11 AM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
This sounds like an alignment problem, that is if you have not had any incident that involved striking the front end or steering gear, both wheels pointing in is called TOE IN, now your car will require a given amount of TOE IN for correct alignment, The correct toe in for your car is 2.5mm this should be checked on an alignment machine, also have the steering and suspension checked for worn of damaged components as well, start here.
mark (mhpautos)
Oct 8, 2010 at 10:42 AM
