1996 Chevy Blazer Belt replacement?
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
CHELSEA26
This morning before work I noticed a noise coming from my engine that sounded like rattling, or like a belt was about to snap. I stupidly thought nothing of it, and it got progressively worse. As I was driving home tonight, the power steering suddenly blew, my battery light came on, the lights dimmed, and the temperature spiked, yet the noise had completey stopped. I drove the 2 miles or so home, but when i pulled into the driveway and shut my car off, I could hear a boiling sound coming from under the hood. Any idea what this could be?
May 8, 2008 at 5:45 PM
  • 31,937 POSTS
With the loss of all accessory rives, you have broken the serpentine drive belt. the noise may well be a pulley bearing failed and the overheating is because the water pump is in-op. you will need to have the belt replaced and checked for noise(faulty bearing) and hopefully you have done no damage to the engine.
mark (mhpautos)
May 8, 2008 at 11:04 PM
