1996 Chevy Blazer Battery gauge
1996 CHEVROLET BLAZER
118,000 MILES • 6 CYL • 4WD • AUTOMATIC
DAVERODMUSIC
My battery gauge is not reading anything when I drive. Also, my speedometer is not reading. When I turn on the lights, thr makes the same sound it does when you leave the lights on when the car is off. What could be causing this?
Oct 21, 2010 at 12:55 AM
HMAC300
  • 48,601 POSTS
charge your battery and then have it checked. If it is ok then have the engine scanned to see if your speedo sender may be bad. you might have a bad ignition switch causing the gauge to screw up or a fuse. but get eth ebattery cheked first s that can effect multiple things if it's bad.
Oct 21, 2010 at 12:24 PM
