1996 Chevy Blazer altinator
TRAVISNOWAK928
  • 1996 CHEVROLET BLAZER
Noises problem
1996 Chevy Blazer
yes I have 96 blazer and the altinator is sqweeling and it wont stop I replaced the battery and it stoped and then the water pump went out and now ever seinc I cant get it to stop
Sunday, February 21st, 2010 AT 7:09 PM
BLUELIGHTNIN6
  • 16,542 POSTS
If drive belt around alternator is OK then the alt. May need rebuilt soon.
Sunday, February 21st, 2010 AT 7:18 PM
TRAVISNOWAK928
Ok I think I might try and replace the belt and if that dont stop then I will go out and buy a new alt. And I have a few more questions to ask. On my blazer my rear wiper on my truck just stoped working the moter is still working but when I turn it on it dose not like to move the wiper blade it seems to be stuck but when I turn it on and go move it it will work could that mean I need a new belt for that or a whole new motor
Tuesday, February 23rd, 2010 AT 9:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Gear may be stripped or the bolt may be loose. Take the cap off at the end of the blade and should have a bolt there, try tightening it up.
Tuesday, February 23rd, 2010 AT 12:10 PM
TRAVISNOWAK928
Ok I will try that when I get back home and see if that stops the problem and that the blade will work lik I said it will move when I go and tap it when its on so im thinking it could just be that cap and how much do you think a new coolent line would cost if I would bring the truck in I have a few things wrong with the car distrubitor cap is bad and the gas gauge dont work replaced the pump and when I did that I filled it up and it went to full and never came down it will move at times when car is off but when its on gose rite back to full
Tuesday, February 23rd, 2010 AT 5:06 PM
