I need to know how to manually disengage the 4wd in my Blazer. I am stuck in 4 HI. I have tried the battery trick...no good... I have pulled apart the push button control and fiddled with that with no luck. Where is my 4WD vacuum hose and f I disconnect that will everything else work ok?
Feb 3, 2008 at 7:33 AM
