ABS lock and brake light comes on
BMORA
  • 1996 CHEVROLET BLAZER
Shakes or Wobbles problem
1996 Chevy Blazer Four Wheel Drive Automatic 157xxx miles
My car will shake, the oil gauge and the speedometer jumps up and down, the abs lock and brake light comes on, and my car will eventually die. If you could tell me what could possibly be causing this I would appreciate it.
Tuesday, July 6th, 2010 AT 11:37 PM
HMAC300
  • 48,601 POSTS
Shaking is usually a sign of a front end problem or balance problem with the tires. It could also be a bad tire as well, try putting the fronts in the back and see if it goes away. As far as the other problem, have your battery checked, but make sure it's fully charged before you do so. Most auto parts stores can check the battery. Also check yoru grounds going to the engine and body, make sure that they are clean as it may not be making a good ground causing the problem. If you disconnect the battery, everything will have to be reset like clock/radio, etc.
Thursday, July 8th, 2010 AT 6:07 PM
