1995 Chevy Blazer Starting issues
196,000 MILES • 6 CYL • 4WD • AUTOMATIC
EDKU07
I have replaced a fuel pump and the whole sender in the tank and still wont start. It will start if i pour gas down the intake manifold. i put the key on accessory and the fuel pressure holds at 58 psi but on the crank it dropped down to 25 on the old pump. So i replaced the pump. Where should I go from there?
Apr 2, 2010 at 4:37 PM
LEGITIMATE007
  • 5,121 POSTS
check the fuel pressure regulator, and for good measure, check the fuel filter
Apr 3, 2010 at 6:29 AM
