1995 Chevy Blazer Rear drum leaking
1995 CHEVROLET BLAZER
151,000 MILES • 6 CYL • 4WD • AUTOMATIC
A.MORRIS1125
I recently bought a 95 blazer from a friend of mine knowing it needed minor repaires. Only repaires made to the braking system was replacing the abs unit. After replacment it worked great but noticed an excessive amount of fluid leaking just after parking it. Looked around and found that the passenger side rear drum brake was leaking fluid. Only a few drops at a time when sitting but apparently a good amount just after stopping. Any Help!??????????
Feb 9, 2009 at 5:09 PM
BMRFIXIT
  • 19,053 POSTS
Clear brake fluid leaking from inside the drum is an indication of a
bad wheel cylinder
need to remove tire , drum and check
replace as needed
good luck
Feb 9, 2009 at 5:15 PM
