1995 Chevy Blazer please help
120,000 MILES • 6 CYL • 4WD • AUTOMATIC
CONRAD
rough start and idle, had tune up 2 months ago, continued to steadily get worse, wont start, changed egr valve, still wont start. what should i do ?
Jan 24, 2009 at 3:51 PM
  • 75,988 POSTS
Next time it refuses to get up and go, do below and tell me what happened
Disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,distributor pick-up coil, ignition control module, cam and crank sensors- Note: If it doesn't apply disregard it
Jan 24, 2009 at 4:03 PM
