1995 Chevy Blazer oil leak but not frm oil filter
163,800 MILES • 6 CYL • 4WD • AUTOMATIC
GMONEY0519
i dont know where my car is leaking oil from
Jun 19, 2008 at 6:53 AM
OBXAUTOMEDIC
  • 3,711 POSTS
[quote:86d4c0f961="gmoney0519"]Engine Mechanical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 163800 miles
i dont know where my car is leaking oil from[/quote:86d4c0f961]
Can you be a little more specific? Were is it wet with oil at.... It could be the front seal, vavle cover gaskets, oil sending switch, Intake, rear seal.....
I suggest you clean the engine. then let it run while you look for the leak.
Jun 19, 2008 at 10:54 AM
