1995 Chevy Blazer Location of Cam Position Sensor
1995 CHEVROLET BLAZER
15,300 MILES • 6 CYL • 4WD • AUTOMATIC
WFLEURY
According to scan code PO300 I need to repalace the cam position sensor. Can you tell me where this is located. Sorry, I am not a Mechanic. I have the sensor.
Mar 6, 2009 at 4:52 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Under hood, center, rear engine area, mounted inside distributor. That code may also appear for faulty wiring to the sensor so if the code reappears after installation of new sensor, inspect wiring.
Thanks for using 2CarPros.com!
Mar 6, 2009 at 5:03 AM
