You have to remove the dash trim cover and the switch has a couple screws through the plastic to hold it in place. Depending on which dash yours has there are a couple hidden screws holding the plastic on as well as the clips.
If you jumpered it and the dimmer part worked on the dash lights it is likely the headlight switch not passing current. If the dimmer didn't change the dash lights then it may be the problem.
Thursday, November 27th, 2008 AT 4:54 PM
