1995 Chevy Blazer idle
1995 CHEVROLET BLAZER
186,000 MILES • 6 CYL • 4WD • AUTOMATIC
TAFLADIE
Blazer idles very high ,almost rips the tranny out if you put into drive. Doesn't always do it though, when it's not idling high it idles rough and backfires sometimes and want's to stall and then sometimes normal. when idling high I have to shut it off and turn back on several times until it's okay to put into drive, tranny is slow to shift if idling high. Have replaced 3 coil packs ran okay for awhile but doesn't seem to help this time. Also have replaced cam shaft sensor ,idle air control sensor, plugs,wires, computer, throttle position sensor, air mass flow sensor. Has been in 3 garages several times and no one seems to be able to figure it out ,pretty much paying for nothing getting expensive . Would appriciate any new ideas. thank you
Feb 8, 2010 at 9:06 AM
2CARPRO JACK
  • 11,533 POSTS
When it is running rough, remove the EGR valve and look for chunks of carbon in the valve seat.If they get in there it creates a lean condition that can cause what you describe.i have seen this on many older 4.3's as they get carbon built up in the EGR system and it breaks free while driving
Feb 9, 2010 at 12:06 AM
