1995 Chevy Blazer idle
1995 CHEVROLET BLAZER
THEATH4
Engine Performance problem
1995 Chevy Blazer 6 cyl Two Wheel Drive 2000 miles
What should I look at next, I have changed the CPI, the Ignition Control Module, the Idle air control valve, and the egr valve and my idle still surges badly at warm up, pretty steady after getting warm, I dont beleive I have a vacuum leak, cant hear one, any help would be aappreciated?
Dec 22, 2009 at 1:04 AM
Check and test the throttle position sensor/manifold absolute pressure sensor-to include a fuel pressure check-Vacuum leaks check with WD-40 around the upper/lower plenum, vacuum hoses. Also test the coolant temperature sensor-
Dec 22, 2009 at 4:45 AM
