1995 Chevy Blazer hello
ROGER007
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 12,018 MILES
Why is it when the headlight on after few minutes the headlight blink?
Saturday, March 27th, 2010 AT 4:30 AM
HMAC300
  • 48,601 POSTS
You may have a short where the headlight harness is broken and hitting against the body, causing this. If it does it all the time the circuit breaker in the headlight switch is going out. Bu tit still could be a short.
Sunday, March 28th, 2010 AT 4:42 PM
ROGER007
  • 38 POSTS
Where I can find the circuit breaker?
Sunday, March 28th, 2010 AT 11:13 PM
HMAC300
  • 48,601 POSTS
The circuit breaker is integrated in the headlight switch. It is a safety feature. If it keeps cliking on and off yu have a short in the system. It can be a broken wire/headlight connection, etc. You will have to find the short.
Monday, March 29th, 2010 AT 11:03 AM
ROGER007
  • 38 POSTS
Ok thanks!
Monday, March 29th, 2010 AT 11:19 PM
ROGER007
  • 38 POSTS
What is the problem of my car the ABS indicator is keep on lighting when I run the car?
Monday, April 5th, 2010 AT 6:34 AM
HMAC300
  • 48,601 POSTS
If you have another problem it shoudl come as anew post as I don't look at mine normally after I get a problem fixed thing. But anyhow you will have to get teh car scanned to see where the problem is, like a bad sensor, broken wire, etc.
Monday, April 5th, 2010 AT 12:30 PM
