1995 Chevy Blazer hello
12,018 MILES • 6 CYL • 4WD • AUTOMATIC
ROGER007
  • 38 POSTS
why is it my car run after few minutes the engine stop
Mar 26, 2010 at 9:01 PM
  • 75,988 POSTS
Check the fuel pressure if its within specs and comeback with the readings we start here.
Mar 26, 2010 at 11:22 PM
ROGER007
  • 38 POSTS
but if i start again the engine start..what is the problem of my car?
Mar 29, 2010 at 4:29 PM
  • 75,988 POSTS
You haven't done what asked you to do -check the fuel pressure to rule out the fuel filter and fuel pump. You start here
Mar 29, 2010 at 5:59 PM
ROGER007
  • 38 POSTS
everything is okay!!!!i have another question when I run my car the ABS indicator is keep on lighting?what is the problem of this matter?
Apr 1, 2010 at 11:12 PM
