1995 Chevy Blazer fuel pump
EHOLLINS
  • 1995 CHEVROLET BLAZER
  • 6 CYL
  • 4WD
  • 200,089 MILES
The car will not started up, but it try to start
Sunday, October 5th, 2008 AT 10:57 AM
MERLIN2021
  • 17,250 POSTS
Start with the basics, and work your way up, Last tune up was? Wires plugs ALL filters? If all that is ok, check for a stuck EGR, then test fuel pump pressure, If it won't restart, determine what's missing, the engine needs three things to run, Spark at all plugs, gas to all cylinders, and compression in all cylinders, tho an engine may run lacking one in one cylinder, it won't run very well!
https://www.2carpros.com/car_repair_video/test_fuel_injection_pressure.htm
Go here and checkout our video.
https://www.2carpros.com/car_repair_video/test_engine_ignition_system.htm
and this one!
Sunday, October 5th, 2008 AT 11:01 AM
