Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Chevrolet
Blazer
Fuel System
Fuel Injector
Replace/Remove
1995 Chevy Blazer fuel injectors are not working.
1995 CHEVROLET BLAZER
149,000 MILES • 6 CYL • 4WD • AUTOMATIC
PDS993
MEMBER
1 POST
i have replaced fuel pump and relay and not getting fuel through injectors.doe's it have a fuel injector relay?
Mar 4, 2010 at 8:31 AM
Experienced Mechanic
Do you have power at the pink wire at the injector harness if not check fuse ECM/IGN fuse no. 10 20amp if okay check the injector ground driver-
Mar 4, 2010 at 9:50 AM
Add image or video
Ask a new question
Engine won't start
Engine stalls while driving
