1995 Chevy Blazer fuel injectors are not working.
149,000 MILES • 6 CYL • 4WD • AUTOMATIC
PDS993
i have replaced fuel pump and relay and not getting fuel through injectors.doe's it have a fuel injector relay?
Mar 4, 2010 at 8:31 AM
  • 75,988 POSTS
Do you have power at the pink wire at the injector harness if not check fuse ECM/IGN fuse no. 10 20amp if okay check the injector ground driver-
Mar 4, 2010 at 9:50 AM
