1995 Chevy Blazer fuel injector
GUSROSS
Engine Mechanical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic
where is the fuel injector relay located???
May 12, 2010 at 7:29 AM
INTERNETMECHANIC
  • 700 POSTS
If you have the spider fuel system, L is the fuel injector. Woops, you ask for the relay, there is no relay. I'm not sure of your vin? Usually the voltage for injector, goes hot when you turn on the key, circuit is fuse protected. The pcm controls the injector on the ground circuit.
https://images.2carpros.com/forum/automotive_pictures/512072_chevy_blazer_fuel_injector_1.jpg
May 13, 2010 at 4:01 AM
