If you have the spider fuel system, L is the fuel injector. Woops, you ask for the relay, there is no relay. I'm not sure of your vin? Usually the voltage for injector, goes hot when you turn on the key, circuit is fuse protected. The pcm controls the injector on the ground circuit.
Thursday, May 13th, 2010 AT 11:01 AM
