The engine will turn over but not start. If I leave the the car sit overnight it will momentarily start then die. ECM fuse is good, replaced fuel pump relay and I have gone down to the tank to listen for the fuel pump operation while my son powers the pump by using the "Fuel Pump Test Terminal" and the pump is working. This problem occoured right after I replaced the front brake pads and took the vehicle for a test drive and gave the vehicle to my daughter. She started the vehicle normally and started driving to the supermarket. She stated that the car just stopped while driving 35 mph.
Oct 12, 2009 at 9:04 AM
