1995 Chevy Blazer engine scan
125,000 MILES • 6 CYL • 2WD • AUTOMATIC
RUSSELL SMELSER
blazer is running rough,obd11 won"t read , was told it was obd1, this scanner won"t fit plug,was there an in experimental system between obd1 and obd11? What should i do? Check engine light comes on then goes off periodically. Thanks Russell
Nov 4, 2009 at 10:41 PM
JDL
  • 16,098 POSTS
welcome, what is your vin? 12 pin datalink connector should be obd 1. 16 pin datalink connector should be obd2. Different connectors. It also could be a hybrid connector. There may be a decal under your hood that says if your fully compliant obd2?
Nov 5, 2009 at 1:50 AM
RUSSELL SMELSER
vin is 1gnc513w852235256, underhood decal. says obd1 certified, but connector is 16 pin. Thanks Russell
Nov 5, 2009 at 9:07 AM
JDL
  • 16,098 POSTS
https://images.2carpros.com/forum/automotive_pictures/170934_chevy_blazer_datalink_connector_1.jpg
You may be able to get flash codes from the cel, by using jumper wire connecting pins 5 and 6. Then turn the key to on, no crank. You count the flashes to get the codes. I can't guarantee that will work. Your decision.
Nov 5, 2009 at 10:15 AM
