1995 Chevy Blazer Engine keeps pulling when I let off the t
ALEXRUNNER
  • 1995 CHEVROLET BLAZER
Engine Performance problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic 125.00 miles
Hello.
My 95 blazer is haveing issues. It idles at two grand so I changed the IAC motor. Stiil does it. And while driving when you let off the gas it keeps going like it was on cruise. I checked all the cables and there free. Someone told me it might be the TPS thats bad
I really dont want to start changing parts to fix it. Id rather change the one part and end the trouble. Period. Your info would be great. Thanks.
Saturday, June 21st, 2008 AT 1:27 PM
MASTERTECHTIM
  • 4,750 POSTS
Your problem is most likely going to be a bad intake manifold plenom gasket. With it idling high try spraying carb cleaner at the base of the intake plenom and if the idle changes then you found the leak. The gasket is easy to change so dont get scared and only cost little money. Let us know how you make out
Sunday, June 22nd, 2008 AT 7:20 AM
