1995 Chevy Blazer compressor
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
GARMUS
how do i know if the compressor is bad just because it makes a noise i added freon 134 and it does not blow cold air
May 21, 2008 at 1:31 PM
LEGITIMATE007
  • 5,121 POSTS
thats one reason, it could seize. it could leak, does your compressor engage? If you put coolant in it, you have to make sure you put enough and it has the oil in it to help condition the o rings and moving parts. but as your putting in the coolant the compressor will cycle on and off and start to cycle off less frequently untill it doesnt go off at all ,unless you turn it off.
May 21, 2008 at 2:48 PM
