1995 Chevy Blazer clanking sound
COCKROACH
  • 6 POSTS
Suspension problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic
ok this a hard one to explain.
on left hand turn i can hear (not always, just most of the time) when i hit bumps on said left hand turn i can hear it better. coming from front vassenger side tire. shocks already replaced.
im not a huge car guys, so what should i be troubleshooting? and how?
from asking around ive gotten that it could be CV joints, ball joints, wheel bearing, or wheel hub?
any ideas?
May 30, 2009 at 6:30 AM
BMRFIXIT
  • 19,053 POSTS
Many things need to be checked check lower control arm bushings and upper too do u hear it at the tire or a bit back under passenger side !! place a floor jack under lower control arm and check ball joints place a bar under the tire and push up check for ball joint movement if under passenger check cross mount ***************************************** need manual CHECK IT @ https://www.2carpros.com/kpages/auto_repair_manuals.htm
https://images.2carpros.com/forum/automotive_pictures/99387_Graphic1_369.jpg
May 31, 2009 at 12:09 AM
