1995 Chevy Blazer A/C blowing hot air after recharging
104,636 MILES • 6 CYL • 4WD • AUTOMATIC
JDGSR57
I have a 1995 Chevy Blazer (vin-W). The A/C is blowing hot air after recharging. The compresser works fine,all the vacuum lines are ok too.
Oct 17, 2010 at 5:10 AM
  • 75,988 POSTS
If the clutch is engaging the compressor Check the air blend door if its stuck on the heat position
Oct 17, 2010 at 8:30 PM
