1995 Chevy Blazer 95 blazer cranks but dont start
150,000 MILES • 6 CYL • 4WD • AUTOMATIC
SMITHJW1
have a 1995 blazer was driving it died and would crank but no start new pump. a week later strated ran fine shut it of will not start. use jumper on test wire for pump it comes on also with key on no cluster lights no turn signals any ideas ? mabye ignition switch? thanks
Nov 22, 2009 at 4:01 AM
  • 75,988 POSTS
Check and test the fusible links and the ignition switch.
Nov 22, 2009 at 4:44 AM
STEVEN49057
I have a 1997 Blazer doing the same thing, turn key on get dash lights & you hear fuel pump kick in & it will start !!!!! If you turn key on & get NO dash lights & hear No fuel pump it will NOT start!!!! If You Find A Fix PLEASE e-mail bassman49057@yahoo.com THANK YOU !!!!!!!!!!
Nov 22, 2009 at 5:53 AM
SMITHJW1
i have checked all the fusible links thay are fine and also the gauges don't work . and i have read on other post that a switch will do strang things
Nov 22, 2009 at 6:52 AM
  • 75,988 POSTS
Fusible links are okay now the power has to go thru the ignition switch to power the rest of the electrical system-Test the switch
Nov 22, 2009 at 7:28 AM
SMITHJW1
how do you test the switch? thanks
Nov 22, 2009 at 7:32 AM
  • 75,988 POSTS
Get somebody with an electrical experience to do it-you might wound up making things worst than it is
Nov 22, 2009 at 8:03 AM
SMITHJW1
i do that sort of stuff at work should just have to check continuity right? thanks
Nov 22, 2009 at 8:11 AM
  • 75,988 POSTS
You're on the right track keep me posted
Nov 22, 2009 at 9:10 AM
