1995 Chevy Blazer 4 wheel drive will not engage
125,000 MILES • 6 CYL • 4WD • AUTOMATIC
XADIDASX27X
i put it in anything other then 2 HI it doesnt go in i dont know what the problem is.
Mar 4, 2009 at 1:07 AM
ROCKBOTTOM222000
  • 12 POSTS
I would first check out your 4 wheel drive actuator which is located beneath your battery. Its like a vacuum. After you get that out, push it in and hold your finger over the hole to see if there is a leak. If there is a leak the acuator wont stay compressed which would mean you would need a new one. If it stays compressed it isnt the actuator. If the actuator is good then it could be the 4wd switch which is easy to replace. It is on top of the transmission and tells the vehicle to engage and disengage the 4wd.
Mar 7, 2009 at 12:09 AM
