Welcome, first check the turn fuse, fuse box under left side of dash. Use testlite, with the key on, there should be a bare spot over each fuse leg, top of fuse. If the testlite comes on at each bare spot, the fuse is good and the circuit has voltage. Next is the turn flasher then the turn switch, as possibilities. I can tell you wiring colors to check, some people want to do their own testing, some don't.
Feb 18, 2010 at 1:30 AM
