computer says fuel rich very rich?
CALLIGETTER
Engine problem
1995 Chevy Blazer V6 Four Wheel Drive Automatic 140000 miles
runs bad computer says fuel rich very rich smell f/ exhaust w/ black smoke
Dec 6, 2007 at 12:27 PM
BLACKOP555
  • 10,386 POSTS
can you tell me the code? or is it a bank sensor code or MAF sensor code?
Dec 6, 2007 at 12:47 PM
  • 55,628 POSTS
this can happen when the fuel injector gets stuck or the fuel pressure regulator goes bad and allows raw fuel into the intake manifold, here is the location of the regulator so you can check it out and I have included this guide to help explain the black smoke as well.
https://www.2carpros.com/articles/engine-black-smoke
I would replace the spider injector because they and problem with those as well. The fuel pressure regulator is where the fuel injector assembly is located.
Jul 8, 2024 at 7:54 AM
