1995 Chevy Blazer
2,000 MILES • 6 CYL • 4WD • AUTOMATIC
PASSERUP
WHEN CAR IS COLD IT BUCKS AND TRIES TO STALL.
THE RPM GAGE GOES NUTS AND THE MESSAGES ON
THE DASH GO ON AND OFF [CHECK BRAKES ETC] INCLUDING THE CHECK ENGINE LITE WHICH SOMETIMES STAYS ON FOR SEVERAL HOURS THEN GOES OFF. AFTER THE ENGINE IS FULLY WARMED UP
IT RUNS FAIRLY DECENT, WITH ONLY AN OCCAISIONAL MISS.GAS MILAGE IS HORRENDOUS,
ABOUT 9.5 MPG. I ALREADY CHANGED THE COOLANT
TEMPERTURE SENSOR TWICE AND THAT DID NOTHING. I HAD THIS ENGINE COMPLETLY REBUILT
WITH ALL NEW COMPONENTS.IT RAN PERFECT FOR ABOUT A YEAR WHEN THIS PROBLEM STARTED.
Nov 16, 2009 at 6:34 AM
JDL
  • 16,098 POSTS
welcome to the forum. If you have the spider fuel system, it is known for problems. Fuel poppets sticking open or closed. I don't know if injector cleaner will help or not? Some of the cleaning procedures I've seen are shop procedures. Use a gage and check fuel pressure.
Nov 16, 2009 at 6:44 AM
