1995 Chevy Blazer
TRACYK
1995 Chevy Blazer 4 cyl Four Wheel Drive Automatic
turns over but want start
Apr 18, 2010 at 9:52 AM
INTERNETMECHANIC
  • 700 POSTS
I have to ask, how long since a tune-up? Have a helper crank it, while you visually check for spark at the plugs. If you have spark everywhere, use a gage and check fuel pressure. Some of the national brand autostores used to loan out a fuel pressure gage, if you don't have one.
I didn't see a 4 cylinder listed for the blazer? You can check for spark by pulling a spark plug wire, stick known good plug/spark tester in the boot, ground metal part of tester to metal part of engine, engine cranking, watch for spark.
Apr 19, 2010 at 7:53 AM
