1995 Chevy Blazer
240,000 MILES • 6 CYL • 4WD • AUTOMATIC
LIMPTURTLE85
I have a 95 blazer that runs good sometimes but most of the time it spits and sputters when you give it more than a quarter of the throttle. then while driving it dies. i wait about five minutes and it starts. sometimes it will do that more than 10 times in an hours time. i have replaced fuel pump, map sensor, 02 sensor, tps, coil, spark plugs wires cap and button, ecm, all filters, and injector. what else is there
Mar 30, 2010 at 5:42 PM
RHALL77
  • 3,361 POSTS
is there any codes or a check engine light on? when it dies, you need to check and see if there is fuel pressure and spark.
Mar 31, 2010 at 1:30 AM
