1995 Chevy Blazer
45,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHEVY BOY86
I HAVE NO POWER TO ANYTHING. THE BATTERY HAS A FULL 12 VOLTS AND ALL THE CONNECTIONS ARE GOOD TO THE ALT., STARTER, AND ALL GROUNDS. I HAVE NO BLOWN FUSES. WHAT ELSE COULD BE THE CAUSE.
Dec 16, 2008 at 7:26 AM
BUDDYCRAIGG
  • 2,262 POSTS
brake lights and horn dead too?
GM trucks have a problem with corrosion on the battery cables.
Especially if there are two positive cables, there is a thick spacer between the two cables that gets coated with a hard green deposit that blocks the flow of electricity.
Dec 16, 2008 at 12:30 PM
