1995 Chevy Blazer
19,000 MILES • V8 • 2WD • AUTOMATIC
AUTIGER2
1995 Blazer,4.3 Vortec will not start. I believe the fuel gage is inaccurate, and ran out of gas. Vehicle will start with the aid of starter fluid for a few seconds. I added 5 gallons of hi-test gas and retried, same result. Start with aid of starter fluid only. I removed in-line fuel filter under frame. It was clogged. I cleaned and replaced. Several times thereafter the vehicle would start for a few seconds only. I have been told there are additional filter or filters in gas line. What do I do next????
Mar 4, 2009 at 5:37 AM
BMRFIXIT
  • 19,053 POSTS
On the Fuel pump
inside fuel tank
if you are to drop the tank replace the fuel pump
i believe its a bad fuel pump
Mar 4, 2009 at 9:54 AM
