1995 Chevy Blazer
115,000 MILES • 6 CYL • 4WD • AUTOMATIC
MELINDASTUMP
what would cause for one to fire out of the coil but not out of the distributor and spark plug wires?
Feb 19, 2009 at 11:43 AM
  • 75,988 POSTS
Check the rotor and cap if need be replace both it has to go thru it before it goes thru wires and plugs.
Feb 19, 2009 at 11:54 AM
MELINDASTUMP
we already have changed the cap and rotor.everyone we have talked to even our local mechanics can't figuere this out.we have even called mechanics in the major dealerships close by and they don't know.we have put new spark plugs and wires cap and rotor rotary button and checked to see if it has jumped time, it didn't.we also checked the ignition censor.please tell me you know something else.
Feb 20, 2009 at 5:40 AM
  • 75,988 POSTS
Have the distributor pick-up coil and ignition control module checked out
Feb 20, 2009 at 7:24 AM
MELINDASTUMP
we also put a new distributor on it still doesn't start
Feb 20, 2009 at 10:13 AM
  • 75,988 POSTS
Are you still not getting spark at the sparkplug wires?
Feb 20, 2009 at 10:18 AM
MELINDASTUMP
there is still no spark at the sparkplug wires
Feb 20, 2009 at 12:07 PM
  • 75,988 POSTS
Do you have power going to the coil from the ignition switch?
Feb 21, 2009 at 7:16 AM
