1995 Chevy Blazer
PETERANDDONNA
  • 23 POSTS
Electrical problem
1995 Chevy Blazer 6 cyl Four Wheel Drive Automatic
i found a broken ground strap just behind gas tank on drivers side(behind gas cap) were does it go and is it imporant would it make truck run bad thanks peter
Aug 20, 2008 at 9:11 AM
2CARPRO JACK
  • 11,533 POSTS
Most likely used to ground the filler neck to prevent sparks. Wont make the truck run poorly
Aug 20, 2008 at 10:14 AM
