u joint replacement
1994 CHEVROLET BLAZER
205,000 MILES • 4 CYL • 4WD • AUTOMATIC
BIGDOG820
ihave a 94 chevy s10 blazer witha 4.3 engine. it is making a knocking noise and shakes a little. how would i replace the u joint? thanks!!!!!1
Jun 17, 2009 at 1:15 AM
SWILLIAMS
  • 597 POSTS
Which one? There are 4 on that vehicle. The rear two are easy to change. Remove the bolts on the rear retainer straps, Pry the caps loose from the yoke. now either place a pan under the output of the transfer case or slide a plug into place HF sells a plug that works well and it's cheap. Now R&R the joints using the proper tools. Front ones are similar BUT you need to remove a few parts and work a bit harder.
Jun 17, 2009 at 6:13 AM
