1994 Chevy Blazer Transmission Problems
1994 CHEVROLET BLAZER
198,000 MILES • 6 CYL • 4WD • AUTOMATIC
JGAS22J
My name is Joseph and I have a 1994 Chevy s-10 blazer. The problem with my car is with the transmission. I believe my transmission is causeing my problem. When I'm driving my blazer will accelerate but it wont shift. As the speed increases your can here and feel that doesn't shift. Is the transmission itself finished or is there something else causeing this. If you know anything please let me know.
THANK YOU!!!
Nov 17, 2009 at 7:42 AM
AJVANDYKE
  • 36 POSTS
First check to make sure your fluid level is ok. Check it while it is running. If it is low add some fluid. Then check to make sure that all of your electrical connectors on your transmission are clean and properly plugged in and none of the wires are damaged. If all of those check out okay you may have an internal transmission problem. Call some of your local transmission shops. Some of those shops can do a free transmission diagnostic for you and you don't have to get dirty! Keep me updated. Good luck.
Nov 17, 2009 at 8:05 AM
