1994 Chevy Blazer i think it may be a
128,000 MILES • 6 CYL • 2WD • AUTOMATIC
IRONHEAD024
i replaced fuel pump , thottle pos. sensor, my asselorator wire was shrating apart i bought that.
Now after fuel pump was replaced it drove but i have recently dropped the tank again i seen that it squirest out of the pump so maybe i have that narrowed down !?
when i done that the blazer would crank but , when you drove away it would die out then leave me stuck.
Now i been buying parts and it isnt helping.
Some one is telling me fuel pressure regulator,where is that located.
If not, what do you think the problem is??
Feb 1, 2010 at 11:12 PM
  • 110,248 POSTS
I would recommend checking fuel pump pressure first. Here is a how to for checking it. It also explaines how to check the fuel puressure regulator.
Let me know what you find.
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Feb 4, 2010 at 2:46 AM
