1994 Chevy Blazer hot rod Sitting long term...
145,000 MILES • V8 • 4WD • AUTOMATIC
OB3135
Hi, I have a 94 K5- Blazer (Tahoe) and I gutted it 4 years ago and dropped in a Crate motor, custom Trannie, auburn gears, whipple super charger, MSD, ceramic headers, Etc... So we are pushing 420 horse or so, it has been setting for about 1.2 years. Ran for 30 minutes a pop maybe twice at idol, the last time we crancked it was about 8 months ago. My question is could there be any internal damage to Rings, Seals,Gaskets, etc... Dry rotting, cracking, deteriation or anything like that. I guess bottom line is can sitting 1 year without running cause internal TERMINAL or internal "must repair" issues???
So now, we fired it up and it is puffing a little black smoke and running kinda ruff, is this bad gas, bad plugs?????
I just dont want to get it running and blow it up or throw a rod because I didnt do something?
Thanks Scott
Jan 21, 2008 at 2:56 AM
MIKE H R
  • 3,094 POSTS
Scott, even crate motors are not run all the time the test them before they crate them some sit for more than a year depending on demand. As far as internal damage, seals can dry out. If you are not going to be running the engine for some time I would use something like stp or a thick lube in the oil so the next time you start it it is not a dry start. Which means there is some lubricant coating the inside of the engine, {rings .lifters, camshaft bearings} The main concern is the gas. After a while gas does go bad. when it does it will leave a varnish coating in the fuel system. There are additives that can be added to extend the life of the gas for a while, but it is best that it is either drain it or run it dry then add fresh gas . I have a trans am sitting in the garage that gets drive about once a year. you can smell the gas. gas that is going bad has a distinctive odor to it. if left and not taken care of will gum up the fuel system. I have seen cars that have been in junk yards for a really long time start right up. I hope that answers your question, If not get in touch with me.
Jan 21, 2008 at 3:17 AM
OB3135
Last one, What about the Tranny fluid, and gear oil... Should they be drained and changed prior to driving it 500 miles to our new home? Are they a danger to thier respecctive parts?
Jan 21, 2008 at 5:30 AM
MIKE H R
  • 3,094 POSTS
If you have kept up regular maintence on the truck the 500 miles should be no problem, check all fluids before you set out and it is a good way to clean out your fuel system pick up a bottle of fuel system cleaner and add some before you fill it up to drive to your new home. that way it will clean the sysem out.
Jan 21, 2008 at 7:34 AM
