1994 Chevy Blazer help
105,365 MILES • 6 CYL • 4WD • AUTOMATIC
JSRROWSEY
I have a 1994 Chevy Blazer 4X4, automatic, 4 Door, 4.3 Vortec V6(remaufactured, with 40,00 miles) When i drive, or idle, park or in drive. At 2500 rpm, my engine starts bogging out, like its running out of gas. Any help would be greatful. Thank you. J.S.R
Oct 14, 2009 at 8:02 AM
  • 75,988 POSTS
Dirty fuel injectors (cleaning the injectors often fixes this).
Bad MAP (manifold absolute pressure) sensor
Bad TPS (throttle position) sensor
Bad or dirty MAF (mass airflow) sensor
Low fuel pressure (leaky fuel pressure regulator or weak fuel pump)
Vacuum leaks (intake manifold, vacuum hoses, throttle body, EGR valve)
Bad gasoline (fuel contaminated with water or too much alcohol)
Sometimes, what feels like a hesitation is actually ignition misfire rather than lean misfire. The causes of ignition misfire may include:
Dirty or worn spark plugs
Bad plug wires
Weak ignition coil
Wet plug wires
Oct 14, 2009 at 10:21 AM
