1994 Chevy Blazer fuel in the exhaust
FRUITY
1994 Chevy Blazer 6 cyl Four Wheel Drive Automatic
have excessive fuel leaking though the exhaust
Aug 3, 2008 at 4:48 AM
BLACKOP555
  • 10,386 POSTS
first i would be checking for a dead cylinder, ground out one cylinder at a time, does one not react at all?
if all are good check the fuel pressure and make sure its not excessive
Aug 3, 2008 at 6:50 AM
GREGVANDAL18
I Had this same problem with my 93 Jimmy last month.
I would try removing the plenum and looking inside the intake. On mine the fuel line inside the plenum feeding the CPI was cracked causing excess fuel to fill my intake and pour down the cylinders. This also filled my oil with gas as well as broke my starter trying to turn it over when the cylinder was full of fuel. lol
Lesson learned
I replaced the fuel feed line and also the return line inside the intake. drained the oil, replaced oil filter and oil, then ran for 10 min then drained the oil and replaced the filter and oil again just to be safe and have put over 1k on mine since then and it has been fine.
Also mine had been hard to start for a month prior. This was the warning sign but I didn't listen. Now it starts like new ;) 225k and still going!
I had also read that the cpi can go out and cause it to add excess fuel but that wasn't the case for me.
Aug 17, 2008 at 8:32 PM
BLACKOP555
  • 10,386 POSTS
sounds like you take care of the vehicle you drive!
and ill vouch for your reply that can cause the problem hes having, and its not as uncommon as one may think.
Aug 18, 2008 at 2:28 AM
