I have a water leak. Are there two freeze plugs in the back of the motor where the tranny hooks up? If not where are the freeze plugs located?
Aug 2, 2010 at 12:00 PM
BLUELIGHTNIN6
✓Experienced Mechanic
there are 2 that can be seen with the wheel off and there is one behind starter as well. freeze plugs rarely fail, you certain plugs are the issue? extremely hard to replace with engine in vehicle if that is the case.
